XJR won't shift out of PARK
The stick is locked in park by an electromagnet. This is engaged to allow movement by foot on brake and physical movement of a microswitch in the shifter housing. These micro switched have been known to fail to open, either sticky or adjustment. Also blown fuse can stop it and I believe that there has been a reported linkage between the taillight wiring shorting in the trunk affecting the circuit associated to the park circuit.
Hope this helps.
(Manual over ride involves unscrewing the plastic 'torx' screw on the shifter and inserting a short rod to disengage the physical lock.
Hope this helps.
I need to buy a service book, these cars have too much going on without one to help lead the path. Thanks for the feedback and pointers. i did find the override and drive the car home. need to figure out next step, will try the air route first hoping that does the trick. If not, will look at the fuse route.
again, thanks for the feedback all, much appreciated.
Received 2,192 Likes
Supraman
I found this Techanical Service Bulletin (206-07) - A/T Selector Lever - Difficult to Shift From PARK
XJ TSB 206-07 Difficult Shift From Park.pdf
Maybe another possiblity???
Jim Lombardi
Jim Lombardi
The following 2 users liked this post by jimlombardi:
dsetter (06-22-2011),
R as in Rocket (12-05-2012)
Rlover
03-30-2016 10:04 PM
neruda
10-18-2015 01:19 PM
