XJR/X308 Differential vs XKR/X100 Differential
Well, I have the dreaded differential whine on my 2003 XJR with 71k miles. After doing some reading, I thought there was a good bet that it would be the output shaft bearings so I sourced a used differential from an XK with 48k miles for less than what it would cost to get one bearing, lol. I knew that the output shafts were the same so I swapped the ones from the XK with mine. No change in the noise whatsoever.
So, since the noise is definitely coming from the differential, it has to be internal. I am lucky enough to have a big shop near me that specializes in differentials and they have done 14hu's before. So, I can take the differential to them for a refresh if I supply the parts. The internal bearings, crush sleeve, seal, etc. are all on order.
To save me some time, it occurred to me that I could give them the XK differential for the rebuild while I spend the hours it will take to remove mine, lol. HOWEVER, I seem to recall in another thread that there are differences between the two differentials but I can't remember the specifics.
I can clearly see that the pinion flanges are different but my question is whether the internals the same or different?
Thanks in advance!
Ben
Thanks in advance!
Ben
benfbrown (04-14-2021)
