XJR X308 leaking oil from rear
Old Today, 02:45 PM
RedXJ40's Avatar
Default XJR X308 leaking oil from rear
Hey guys,
How are you doing?
I have an XJR which is leaking which i believe is engine oil.
It seems oil drips from the transmission housing?
Could be the rear main seal but there is a connector above where it's dripping what is covered in oil also.
The bolt of that connector is tight.
I don't know if that connector could leak.
Please see my video, maybe you can push me in the right direction.
Maybe coincedence but the leak started after an oil change and it seems they filled it up with too much oil?
Dipstick
Old Today, 03:27 PM
RJ237's Avatar
Received 2,797 Likes on 2,235 Posts
If you have eliminated valve cover gasket leakage there are two common sources: The rear main seal and the oil gallery plug above the rear main seal.
motorcarman (Today)
scooterforever
17
09-30-2023 11:56 PM
ExcelsiorZ
04-03-2022 06:40 PM
earny
07-29-2021 10:57 AM
mustangtyson
08-12-2014 12:42 PM
topheaded
11-29-2013 03:51 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Quick Reply: XJR X308 leaking oil from rear
