XK8 LH door not being recognised
Sorry , the XK8 is on a different forum as this is the 4 door XJ8
1997 XK8 Wiring Guide pdf
http://www.mediafire.com/file/c9hb6z...Electrical.pdf
Driver door switch page 91
Window lifts page 95 :
Fuse # 15 / 25 amp Driver Side Fuse Box ( RHD )
You can open up the door panel and put 12 volt battery charger power on the motor wires to verify the mechanism works or needs lubing . High current arcing hazard .
Look for pushed back sockets on the driver door control module connector as I found one wire unlocked and pushed back on a other 96 Jaguar
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
Digital Will
03-06-2020 03:50 PM
