xk8 rims on an xjr?
Guest
Posts: n/a
I was thinking about buying a set of giovanni rims for my 2000 xjr because the black ones I have with the silver just aren't cutting it. The guy I'm buying them from had them on his 1998 xk8. Are the bolt patterns the same on the xk and xj models?
[align=left] [/align]
Found this, not sure if accurate or not.
1998 Jaguar
XK8
Bolt Pattern: 5x120.65
Center Bore: 73.9
Hardware:1/2 Lug
Offset: 15-25mm
2000 Jaguar
XJ
Center Bore: 73.9
Hardware:1/2 Lug
Offset: 15-25mm
So, in this case, yes. I have read other locations (roadfly) that the XK and XJ do have similar bolt patterns, but mostly the 2003 model years and under...older models.
1998 Jaguar
XK8
Center Bore: 73.9
Hardware:1/2 Lug
Offset: 15-25mm
2000 Jaguar
XJ
Center Bore: 73.9
Hardware:1/2 Lug
Offset: 15-25mm
Mine are currently staggered, 19x8 and 19x9. I was thinking of going with these knockoffs. 0.5" wider than my current Apollos.
![](http://www.eurotechwheels.com/010silvergallery.jpg)
lickahotskillet
10-18-2015 09:51 AM
