Yet another interior illumination question,
Are the fan,lock/key & Valet buttons(see red marks) supposed to be back lit ?!
Edit :
Never mind I found my answer(search was malfunctioning earlier) wow I'm missing more than I thought lol. Now I just need the bulb #s as I don't want LEDs.
https://www.jaguarforums.com/forum/x...e-light-40725/
Edit :
My own previous post but I can't figure out which ones I need as my fan,valet,unlock & temp up & down should all be the same color yet I see green,blue & clear listed as console button bulbs lol ?!
Clock Bulb
LNC5180AA
or
EiKO Clear 2721MF Incandescent Bulb(cheaper & readily available OEM replacement just reuse the blue cap/filter)
Dash/Instrument Cluster
LJA4390AA
Door Switch Packs
Passenger 1 per door : DBC6244
Driver 2 of each : DBC6244 & LNA518CA
Warning Light
LJA4390BA
Console Switch Bulb Blue
LNA5180DA
Console Switch Bulb Clear
LNA5180EA
Courtesy Lamp
DBC11381
Trunk Lamp
LNA5180AA
Puddle Lamp
XR811819 or DBC11381
Glovebox
DBC11380
Visor Bulb
LJA5180BA
A/C LCD
JLM11965
Low Blue
JLM20308
Low Green
JLM20309
LNC5180AA
or
LJA4390AA
Door Switch Packs
Warning Light
LJA4390BA
LNA5180DA
LNA5180EA
Courtesy Lamp
DBC11381
Trunk Lamp
LNA5180AA
Puddle Lamp
Glovebox
DBC11380
Visor Bulb
LJA5180BA
A/C LCD
JLM11965
Low Blue
JLM20308
Low Green
JLM20309
Ok making progress but JagBit's is stumped as well. I've deciphered from looking @ the back of one on ebay. I need the 65 MA Blue & Clear bulbs. But still zero ideas as to what the fan knob buttons & temp up & down require.
I'm going to buy a damaged one off Ebay for $15 & disect for bulb info. I will finally document this info. Jagbits,SNG all drawing the same blanks as me. $15 scrapper sure beats $120 in bulbs I may not need lol.
Jagbits isn't stumped lol I emailed you the parts diagram, quantities and part numbers LOL!!!
That leaves me a choice between 4 bulbs lol, No worries I ordered a donor panel, seriously over engineered though.
I need these.
Yeah no problem I solved that bulb riddle last year lol. Hard to believe someone thought it was a good idea to have so many buttons w/ varying bulbs. I don't want LEDs as I find them too bright for this application. Even with the donor on it's way I'm already seeing there's 2 blue bulbs that look the same but have different part # & it's not the superseded replaced bulb scenario as they are both still listed in the same panel, just not by exact location lol.
Edit :
One thing's for certain when my donor panel arrives I will take pics of it dismantled & document the bulbs needed. The interior bulb schematics on these cars is convoluted & spread about the web, then you have the bulb # is now superseded by bulb # scenario, it makes a should be easy task a long drawn chore. A thread w/ everything clearly stated would have saved me a few grey hairs lol.
Even w/ the diagram for the bottom part(without Valet,Heated seats etc.) there's 14 lights the diagram accounts for 11.
Edit :
Armstrong
05-02-2017 07:19 AM
motorcarsrandy
02-11-2014 06:45 AM
