Your 2019 "To Do List"
#41
Steering wheel upgrade to the half wood unit DONE
Brake calipers either painted or covered
Upgrading head & fog lights to the brightest halogen available DONE
Deep cleansing,conditioning & dye refurbishing of the seats
Wood panels restored
Defroster vents replaced DONE
Full paint job DONE
Full paint job DONE
chris-jag (11-21-2019)
#42
Steering wheel upgrade to the half wood unitDONE
Full paint job DONE
Full paint job DONE
Replace climate control panel bulbs
#43
Things planned for 2019..................
1) Trunk Struts DONE
2) Intake valley heater hoses and 3-way valve. DONE
3) Metal Thermostat tower. DONE
4) Really minor, but that small rubber bushing that supports the airbox was broken, so I replaced it. DONE
5) OEM Ruby Red wheel centers DONE
6) Larger exhaust tips DONE.
#44
7) Console temperature display bulbs. One bulb would go out occasionally, and light if I banged the console, but now it won't light even with a bang, so that is the "last" thing on the list. Reading about KC's bulbs saga has prompted me to get off my a** and get this done....
#45
to me, it is always a full list of things to repair, I need
repaint/repair both front and rear bumpers
repaint/repair both front doors
(if anyone has to information for the parts)
upgrade to a larger inter-cooler( I got it already, need to install)
upgrade to lower S/C pulley(done the upper pulley already)
need a new pair of headlight housings
lower sprigs
ultra racing under bars
Mina metal intake pipe
on my dream list, the Arden Body kit.
lower sprigs
#46
Full paint job DONE
Replace climate control panel bulbs DONE
Full paint job DONE
Steady progression !
#47
Brake calipers either painted or covered DONE
Full paint job DONE
Full paint job DONE
#49
All info's below, yes they are custom made/form fitting.
https://www.calipercovers.com/
https://www.jaguarforums.com/forum/x...2/#post2067774
https://www.jaguarforums.com/forum/x...08-xjr-102878/
#50
#51
I can focus on my XJ again now that I’ve completed the restoration of my other car. My problem of late has been rain, it’s been raining for around 2 weeks here, but it’s dry today so I can have a check over the XJ ready for her MOT test next week. Things I need to do will take me into 2020, but I don’t mind. The worst thing for me is not to have anything to do on the cars.
Jessie Jag is 17 years old now and she requires a few things that I’ll work through slowly.
1) Pair of new Catalytic Converters
2) Front & Rear suspension overhaul to include shock absorbers, bushes and repainted components.
3) Pair of Front tyres to match rears.
4) Rust repair to RH front wing and both front sill edges. (Looks like the salty roads at Christmas got through)
5) Diff oil change.
6) Interior cleansing including repair to driver’s seat & installation of rear seat heaters (just because I can)
7) Metal thermostat tower installation (Izvestia had this thing since I bought the car, just haven’t got round to it)
8) A/C system recharge, it’s been a couple of years.
9) Parking sensor issue, system will only work in dry weather, possibly a bad sensor.
10) The other little things that will reveal themselves along the way
5) Diff oil change.
#52
Marisol Espinoza
Customer Service MGP Caliper Covers
marisol.espinoza@calipercovers.com
877.995.0003 x7060 office 619.330.4609 fax
#53
#54
I thought it was time this thread was revitalized..........
These are the things I planned for 2019, and got done..................
3) Metal thermostat tower. DONE
7) Center console bulbs DONE
And now I can add the ABS module. I have had the "TRAC/ABS not available" light come occasionally, but the last couple of weeks it became a near-constant fixture, so now it's done too.
8) ABS module repair. DONE
It's good to have a "To-Do" list, and fingers crossed, it feels really good that I don't have anything on that list right now......hopefully it stays that way!
Craig Mason (07-24-2019)
#55
Well, my main objective for 2019 - Sell it - hasn't gone as planned. People are even cheaper these days than usual. So... I'll leave the ad up but in the meantime, I've decided I'll start working through my new list on my own, and adjust the price accordingly as things get crossed off.
EDIT: And an hour after I posted, a guy that had originally low-balled me, came back to meet my offer. We'll see lol. Good thing I hadn't hit the Checkout button on my cart yet!
- Trace out the P0455 issue. That's the big one, since I can't put it back on the road without it.
- Troubleshoot the stiff/jerky steering wheel issue. It might need a new rack, or something in a joint rusted up, not sure yet.
- Replace missing washer reservoir
- Adjust the brake pedal switch
- Hook up the parking brake cables (they're in place, just zipped out of the way after replacing the hub assemblies in the snow)
- New valve cover gaskets
- New Trunk Struts
- New Pads and Rotors all four corners
- New Tires
#57
As I expected, he backed out of the deal. Imagine my surprise that people with no knowledge of the car, or those who won't due proper research, see miles as the end-all, be-all. Oh well, back to planning on fixing bits.
#58
Yes I bought mine w/ higher than wanted mileage but I did so seeing the history w/ tensioners etc. done. Mind you this is my 3rd run w/ the 308s so I like to think I'm well versed lol.
#59
...in order of priority...
Get one (necessary) or both engine mounts replaced
Figure out how to get out screw holding down MAF sensor...seeme to be replacement screw that doesn't want to turn
Replace right rear spring insulator
Replace front shocks/mounts
Replace thermostat housing...looks OK but I've read the horror stories
58k miles
58k miles
#60
Slow Progress...
Fit new PAS pump
2.3 S/C drive ratio-Needs machining of the snout- which I have to get around to doing. Need to do it still mounted which will be the challenge
Upgraded intercooler radiator-Am waiting on my contact to get back to me
New upgraded high capacity electric pump (Pierburg "AMG"- if it fits)-Better than the Bosch "010" type-still researching into this
200 cell catalysts-bought the cats, but they are for a later X100 XKR and the mounting brackets are different and need modifying
opened out throttle body-in process
Machined throt flange duct into S/C-Not Done
Bonnet Louvres-moron is dragging his heals with the CAD
Rear Boot Lip-bought
Respray and blend of bonnet- Still to do
Fit new colour scheme Instrument cluster gauges-still to do
Retrim XJR-100 steering wheel with alcantara upper and lower trim and re do the stitching-My retrimmer is taking his time, will check today
New Rear wheel bearings-booked in for Aug 7th
New rear axle U-Joints-booked in for Aug 7th
Buying another 2 cars and the shennanigans with the Ram didn't help matters.....(E type and X type)
