ZF5HP-24 Transmission fluid
Okay, I've researched this up the ying-yang, but I don't seem to find a positive answer.
Apparently the original transmission fluid in our X308 ZF5HP-24 automatic transmissions was Esso LT-71141, a semi-synthetic fluid.
1) Is this still available (Esso became Mobil which became Exxon ......or something like that).
2) If Esso is not available, what should be used?
I'm having the Transgo mod done soon and wanted to be sure they use the "correct" fluid.
I ordered off of eBay when I serviced mine a few years ago. Here's a couple of current links to the type of fluid I ordered. I drove the car another 10,000 miles after the service without a hiccup.
https://www.ebay.com/itm/ZF-LIFEGUAR...aIpmHA&vxp=mtr
https://www.ebay.com/itm/Audi-BMW-Ja...BZHaFX&vxp=mtr
It appears to be made by the same company that made the transmission.
Febi Bilstein ATF Transmission Fluid is Esso LT 71141 equivalent & fairly priced.
https://www.ebay.com/itm/5-Liters-AT...-/361447478663
The following 2 users liked this post by King Charles:
motorcarman (03-24-2018),
Tinsletown (03-24-2018)
BKSinAZ
02-21-2015 02:02 AM
rainbowboy
09-09-2013 12:48 AM
