1988-89 XJ40 door handles alternate fix
After replacing about 20 (it feels like) door handles on my xj40. I wanted to figure out a fix for it and here is my fix.
Theory:
Use a 60lb shaved door kit to pull the inter opening lever, with a switch connected to the door handle to activate the solenoid. I figured that the 60lb being the largest you can buy, should be strong enough pull the lever.
I ordered it for 45$ bucks, received it and tried to install it. There were two problems with the 60lb solenoid. First one being it is huge! I could not find a good spot anywhere that it could fit and was still able to use it. The second one being its sounds like a jackhammer in the door when it is turned on.
60lb kit
So after thinking for a bit I decided to go with a lower poundage which makes it smaller in size. While looking for one I come across a "Universal Power Door Lock Actuator" which is rated at 11lb for 4$ bucks. I thought for 4$ if it was not strong enough it wasn't that big of loss.
Lock Actuator
I received it today, I installed it and it works great!
It pulls the lever very easily and you can not hardly hear it at all.
Here is a couple of pics of it installed.
![](http://foothillscommunityworkshop.org/wp-content/uploads/2011/11/2011-11-01-15.11.12.jpg)
Theory:
60lb kit
Lock Actuator
![](http://foothillscommunityworkshop.org/wp-content/uploads/2011/11/2011-11-01-15.11.03.jpg)
This thread is two years old and danzar hasn't posted for over a year so you may not get a reply.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Richard A. Stolfa (02-19-2017)
I've only just noticed your post. This thread really should have been on XJ40 forum so I've moved it.
danzar was last on the forum 12-12-2013 10:57 PM. Unlikely you will get a reply but others here with the same model may be able to help.
Don B (03-13-2017)
Johnny_B
10-10-2016 11:45 PM
