Hey Jaguar lovers.... I have a question. What is the name of the very small belt connecting to the fan belt on my jag? I have changed all belts except for this belt and it causes my car to squeak for about 2 mins when i first start my car up. I think the size is a 13x1150 but i cant find this belt anywhere. I tried different part stores and they cant locate or identify the exact belt and size i need. I think its the drive accessory belt that connects to the fan belt but im not sure. It is an original stock belt that is still on my jaguar but its going bad. It has jaguar logos printed on the outer part of the belt. If anyone has the answer to this problem i would greatly appreciate it if the knowledge of what the belt is exactly called and where can i find another one to purchase is shared with me. I need replies ASAP thanks Jag lovers and have a good day!
I believe your 3.6L engine has a main belt that drives the alternator and water pump from the crankshaft (1); a second shorter belt that drives the air conditioning compressor from the crankshaft (2); and a third, even shorter belt, that drives the secondary air injection air pump from the water pump pulley (3).
I believe your 3.6L engine has a main belt that drives the alternator and water pump from the crankshaft; a second shorter belt that drives the air conditioning compressor from the crankshaft; and a third, even shorter belt, that drives the secondary air injection air pump from the water pump pulley.
Here's the diagram from jaguarclassicparts.com:
Cheers,
Don
Thanks i found it and ordered it off of parts geek.com and found the exact match. Now thats love mannn!
