1988 XJ 6 inframe
It can be done and is a great time saver. You will nead a lift,a tall tranny jack (oe fork lift) .Remove whole assembly just disconnect brake hoses and sreering hoses and linkages.You will also have to support the motor when the crossmember is out. Then you have plenty of room. You still will have to take top end off for the job.
Thanks,I took the callipers of front assembly to save bleeding brakes,held front of motor up with ratchete straps and once sub frame was out held motor with straps to engine mounts and wheeled sub out with floor jack,didn't take long at all,Kiwi
FS[NorthEast]: 1988 Jaguar XJS H&E Project in Vermont
somoflange
09-16-2015 10:16 AM
