1988 XJ6 Passenger Side stop/indicator light issues
I have a 1988 jag XJ6. The passenger side stop, indicator, and tail lights were all out. I discovered it was a blown capacitor in the circuit board of the bulb failure module as well as a blown fuse. I replaced the module as well as the fuse. Now the tail light works all of the time but the indicator and stop lights only work intermittently. I have looked for any visible split wires and checked all of the connections. Any ideas what else it might be?
I am grasping at straws here, but I just had this intermittent bulb happening to me too: I was trying to fix a rear turn lamp. I shined up the contacts in the socket and made sure the bulb was clean. What it turned out that I had was a broken but not burned off filament in the bulb. You're sure your bulbs are good? Good luck. Keep us posted.
The following 3 users liked this post by Hagered:
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
