1989 XJ40 Cener Fuse Panel is DEAD
Guest
Posts: n/a
Hello Everyone
I was working onmy broken instrument panel clusterand when I got it back together, the car does not crank and the radio is dead. I took a test light and all of thefuses in the center fuse panel are DEAD but good fuses. There is no power there. My Haynes manual says there is a direct connection to both of my problems in this center fuse panel.
How is thecenter fuse panel powered? What could have happened that caused the loss of power to the center fuse panel? If I can figure that out, I think I my problem will be solved.
Any suggestions would be most appreciated!
Thanks!
Rich
Dubble6s
Thanks!
Rich
Dubble6s
rsa760041
23
09-25-2015 01:33 PM
