1989 XJ6 battery drain
My 89 xj6 has a battery drain. There is a digital beeping coming from the steering column. I think it does that intermittently during the night. What is that sound for? Is that my drain. I've done an amp draw test and have. .02-.03 amps when everything is off. Please help.....
Welcome to the forum Marc,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
Received 13,425 Likes
Welcome to the Jaguar Forums! It's great to have you with us.
My first guess is that the dust cover flap in the ignition key lock barrel is not closing properly when the key is removed, causing the "key in ignition" chime to sound continuously and running down your battery. You can usually free up the flap by applying a little penetrating oil to the key and repeatedly inserting it and turning it until the flap closes reliably.
Cheers,
Don
93SB (03-07-2018)
guanshee
10-17-2016 06:19 AM
Michal
10-16-2016 04:23 PM
muskox3437
10-09-2016 05:29 PM
