1990 -Oil Leak O Rings-Hose???
It seems that my oil leak is coming from the oil lines lines that are at the engine block. Would this most likely be the O rings failing or can the hose connection also fail? Any tricks for taking these off? They are in a tight spot( I'm not the smallest guy on my street, if you know what I mean)
Frank
Frank
Peeam
09-22-2015 05:15 AM
