1990 XJ40 4.0l Performance Improvement?
I have a 4.0l Xj40 and am looking to complete some modest upgrades to boost HP.
I have looked at the AJ6 Engineering site, and have read good reviews - though wanted to educate myself a bit more upon possible set ups before contacting the company.
I believe the stock set up is 240 HP - I would like to get a 15% gain if possible.
Thank you,
Thank you,
In the 1980s and 1990s, several tuning companies offered vastly expensive twin turbocharged versions of the XJ40, at least in Europe.
Janspeed's TwinTurbo 3.6 produced 290-odd bhp and an unaltered ZF4HP22 (non-electronically controlled forerunner of the ZF4HP24 used in the 4 litre). Quite a few of these were sold and many of them are still on the road and have not suffered reliability problems even at big mileages. Germany's well known 'Arden' Biturbo 3.6 was more powerful still, with 330bhp and 322lb ft, also used the standard gearbox without issues.
Later 4 litre cars were modified by Chasseur, and called "Stealth" Jaguars. These used a Turbo Technics installation, generally of 340 bhp / 405lb ft and used an unaltered ZF4HP24 transmission without any adverse reliability problems. Again, these are less rare than you'd think and I know of a couple which have done big mileages without problems. Chasseur offered up to 460bhp in the XJ40, but I don't know which transmission they used for this.
A 15% increase in power will be well within the capabilites of the transmission.
David
The 4 litre XJ40 uses a ZF4HP24 gearbox, while the V12 uses a GM unit. I don't know the official torque limits for the ZF, but they are a very robust transmission and the standard 4 litre engine's power out must be well within its capabilites.
David
David
Thank you for the post.
Any idea of where to source these products?
I check ebay.co.uk though if you have any suggestions, much appreciated.
Flling up with 100 octane wont do any more good than say 91 octane in these cars. All the octane does is allow higher compresson before preignition occurs. It also makes for a less explosive combustion IIRC.
I had a half tank of 91 octane and dumped a quart of Xylene into it and it ran no different.
