1990 xj6 transmission light on dash
Most of us that own jags 90-94 have seen that light as well. Your car is in "limp" mode. Do a search here in the forum, plenty of good stuff to help find and fix it. From very easy to a little more intense. Don't panic
omega:
Yes, don't panic. This is a fairly common event for this car. Suspect the mechanics of the transmission only as a last resort. There is so much else it could be, which is now your job to track down. The average mechanic is probably not going to take the time to work through the process of elimination required. The good news is that it could be something pretty simple. There is an excellent, systematic step-by-step process for trouble shooting the tranny-light/Limp mode on the Jag-Lovers site as part of the XJ40 e-book. It is sticky-linked in the FAQ portion of this forum. Go there and read all about it. Let us know if you are having any problems, but more especially how you are getting on and what you discover remedies the problem.
Good luck!
Scott
Good luck!
Scott
jtk456 (04-02-2014)
