1991 XJ40 Stalling Issue - RESOLVED!
My vehicle turns on fine. Doesnt stall while in park. Once I start driving everything is fine, as I come to a stop sign or slow down, the engine starts to shake and wants to turn off. Sometimes it turns off and other times it doesn't. I turn it back on without issue and continue driving untill it reaches operating temperature. When the engine is warm, especailly in the summer, this problem doesnt occur. Which sensor might be malfunctioning? Perhaps the mass air flow sensor is dirty, or the throttle body needs a cleaning. Throttle positioning sensor? Idle air control valve? Air intake temp sensor? or the Oxygen sensor?
Received 13,349 Likes
One issue that has been associated with stalling while slowing to stop or make a turn is low transmission fluid.
To accurately check your fluid, drive the car till the engine reaches full operating temperature - usually at least 15 minutes or more. Then park on a level surface. Set the hand brake. With your foot on the brake pedal, move the gear shift lever through each position (RND32), pausing in each position at least 3 seconds. This fills the valve body passages with fluid to give the most accurate fluid level reading. Put the transmission back into Park. Now check the fluid level. It should be exactly at the maximum/hot line on the dipstick. If you don't have a clear line in the fluid on the dipstick, wipe off the stick and reinsert it down the tube. Repeat until you have a clear line of fluid on the dipstick. If the fluid is a pint or more low (or high), transmission performance can be affected. If the fluid is low, the engine may stall when slowing to a stop or to make a turn.
Another thing you can do is check for any diagnostic trouble codes (DTC) that may be stored in the Vehicle Condition Monitor. To check, turn the ignition key to position II (ON) but don't start the engine. Press and release the VCM button on the trip computer to the right of the steering wheel. Now watch for any message to appear in the small display below the speedometer where the odometer/mileage counter normally appears. DTCs appear in the form of "FF" or "Fuel Fault" and a one- or two-digit number, such as "FF69" or "Fuel Fault 24." Let us know if you have a code stored and we'll try to help.
Cheers,
Don
Don B (02-28-2023)
Synthetic options include Mobil 1 ATF and Redline Oil D4 ATF.
Despite claims that Dexron VI is backward-compatible for Dex II/III applications, its viscosity is too low and it does not work optimally in the ZF 4HP24 transmission. I used it for a couple of years in our '93 XJ40 and didn't realize until I changed to Redline Oil D4 that with the Dexron VI, the torque converter was not transferring power properly. When I changed to the Redline, the transmission felt "hooked up" again, with better acceleration, better engine braking when descending hills, and a much more significant difference between Normal and Sport modes.
Cheers,
Don
The following 2 users liked this post by Don B:
EssOess (03-11-2023),
YoungBosnian (05-23-2023)
Received 1,083 Likes
The following 2 users liked this post by YoungBosnian:
Don B (05-23-2023),
motorcarman (05-24-2023)
AmDazed
01-24-2019 10:10 AM
