1991 XJ6, No Speedometer or Tack Lights
Guest
Posts: n/a
Hello fellow Jag owners, I finaly Got my Jag running. It turned out to be the coil, it was not putting out enough volts. Now that I got it running there are no lights in the gauges, { speedometer, tack ] the rest of the lights are working just fine, you can dim them, or make them brighter, but there are no lights in those two. I checked all the fuses, and none are bad. Could use some help. Thanks
rusty37
04-05-2020 07:40 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
1991, 2001, 91, brightness, function, fuse, jaguar, jaquar, lighting, speedometer, speedomoter, speedomter, tacklights, working, xf, xj6, xj8
