1992 Jaguar xj6 throttle bog?
Hello all,
Picking back up on one of my projects. I replaced the oil/filter, reconditioned injectors, new spark plugs and wires. New shocks and shock bushings all the way around. Fixed all the vacuum lines and mice eaten wires. I get throttle bog. I didn't replace the cap/rotor yet but wondering if this could be the culprit or something else I need to be looking at? Also noticed it doesn't start well cold, I need to hold the gas pedal till it warms up for about a minute.
Thanks in advance,
Leo
Thanks in advance,
Leo
The following 2 users liked this post by Lawrence:
Don B (08-26-2020),
MountainMan (08-29-2020)
Try cleaning the intake plumbing hoses, replace the air filter, clean the throttle body and set butterfly to specs. Then clean and decarbonize the idle control valve and valve body and reset the idle valve. That should do it ...oh -and change the cap and rotor too!
Larry
Larry
It's on top of the intake manifold about 2/3rds of the way back towards the firewall, has an oval plug about an inch or so and the reset procedure is here:
Jag-lovers' Ebooks Book Index
hth
Larry
hth
Larry
Don B (08-26-2020),
The following 2 users liked this post by MPDano:
93SB (08-29-2020),
The following 2 users liked this post by jerry_hoback:
Don B (08-25-2020),
Id say you have a bit of a vacuum leak there. That hose is available from Barratts or Moss motors. Its not extremely expensive either as i recall, though times have changed....... Definitely check for other leaks too, as that one would mask several others... Good luck!
I used black rtv for now to seal it while I wait on the order. I got a new CL, assuming now that I fixed the leak. I drove it around and same bog, really feels like not enough fuel. I replaced the cap and rotor before my test drive. I'm going to replace the fuel filter and re-test drive. Here is a picture of the CL
jerry_hoback (08-25-2020)
Don B (08-25-2020),
