1993 Vanden Plas help!!
We went out last night to go to dinner. It was very cold around 20 degrees out. We drove about 19 miles and the heat in the vehicle never warmed up, until we got to the restaurant. When we left the car started up and we jumped on the freeway. We were going up a hill and the jag started to loss power. I pulled over and after about 1000 feet died. It fired back up. It did hesitate a bit. Once it started to run we drove about 1 more mile and died again and wouldn't start back up. When we drove it if I gave it any gas it would start to stall out. We towed it back home and while in tow the engine stayed on the whole time about 15 miles. I did drive it into the garage. The engine check light came on about 1 week ago with code 37. I had just filled the tank and didn't think much of it. We drove about 200 miles with the code and no problems. Now I'm lost!!
Welcome to the forum, if you haven't done so please go introduce yourself in the new member section.
That 37 code is an ECU to EGR issue. Plenty on it here in the forum, use the search functions. Get yourself a Haynes manual and a XJ6 Drivers manual. Sounds like your car has intermittent issues with the fuel pump, sometimes it's starving for fuel. 93 Jag huh? I believe that pump is in the tank. Go search for this and download it, you will use it quite a bit. AJ6 Engine Management System Diagnostic Guide.
Cadillac (12-07-2011)
Good luck!
Just saw your post and don't know if you solved the problem, several have mentioned the fuel pump and checking the fuel pressure, but I don't see where anyone has mentioned the other obvious check if low pressure, the fuel filter may be clogged which would be a relatively simple, i.e., inexpensive, fix. Not sure if this will affect the code 37. It is often not obvious how something impacts a sensor. Good luck.
FS[SouthWest]: Parting out 1999 Vanden Plas
Brewmonkey
21
05-30-2016 12:50 AM
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
