1993 xj6 blue smoke
hey ive got a 1993 jag xj6 and well ive got a bit of blue smoke wen i start it up im just wondering do i need to start freaking and umm weres a good place to get a book on how to fix a jag and parts and or a good place to get it fixed between vancouver and chiliwack at a some wat decent price called mcl motors and they wanted 4000 to fix it and they said it could be the valve seals i was like f that so yarg thanks for the input
The 1993/94 were the worst offenders for the 'blue smoke at startup'. I have replaced the valve stem seals with the head on the engine and with it removed (it can be done either way). You can buy ALOT of oil for the time and money it will take to replace the stem seals......
If my 1992 XJ40 smoked at startup I would not look in the rearview mirror at startup.
bob gauff
bob gauff
If it's blue smoke only on startup, I wouldn't worry for now, but it is possible it can get worse eventually - just make sure there is definitely no blue smoke when the engine is idling and at higher revs.
Check your engine oil level regularly to monitor increasing oil consumption - that's when you will have to do something about it...
sneby09 (06-15-2011)
