1994 4.0 s cooling fan dont turn off
I believe Series IIIs suffered from this culprit you mentioned , fans stuck on .
Sorry ,I can't give you the best idea apart from removing the fan relay each time you stop the engine .
You will prolly end up buying a fan relay ,I hope that's that .
Mine nowadays developed a strange problem , just as I insert the key and even when the engine is dead cold , fans start running on their own along with low coolant light on the dash .
Thanks , I can give you some addresses
www.britishparts.co.uk (since you're in the UK )
Nalley Jaguar , JPAM (those are our vendors )
www.jagbits.com
www.motorcarsltd.com
I believe you can find the relay you need
or
www.ebay.co.uk
www.jagbits.com
or
www.ebay.co.uk
Hi
My 1994 4.0 S just did the same today: fan won't stop.
I just had the air conditioning refrigerant refilled today, and after/during the refill the problem mysteriously began. This should have nothing to do with the fan, but what can you do
However, now the problem is that I can't locate the fan relay, but have to disconnect the battery to cut the fan power. Haynes tells that the relay should be in the LH front corner, but I can't find it? Does the relay look different from normal relays, or should I look somewhere else?
jaguar4litre53
hi there
Its under the front left hand side of the valance (nearside England).
Six screws hold a approx six inch square of splash shield, remove this and look up you will seeit you will probably want a torch. Its about 3 inches long about an inch of it being white the other two inches being green.
Hope this helps. Good luck
