1994 Dash Panel Lights/ A/C Evaporator
Guest
Posts: n/a
I have a 1994 V6 that I have owned since '95. Slowly but surely things are starting to deteriorate. Would someone please tell me how to gain access to:
1: Dash Panel lights. All of my instument pack lights will not light up.
2: Evaporator/Dash Removal? My A/C freon leaked from behind the dash and fell to the floor. I also noticed some freon outside of the car rising up from the vents near the windshield wipers.
Any insight to either of these issues is greatly appreciated.
Thanks in advance!
Thanks in advance!
Guest
Posts: n/a
1: Doesn't seem to be a ground or a fuse. Someone told me to check the dimmer switch because the odometer is visible until the headlight switch is turned on. With the light switch on, the odometere is not visible. Turn the headlight switch off and the odometer is again visible.
2: Freon. It is heavier than air and lays on the floor until I open the door. You can smell the freon. Also, something, guessing freon, was "steaming" up out of the vent near the wipers. This occured once during a/c usage on a hot day. Thought maybe an expansion valve was bleeding off.....
