1994 Jaguar XJ12 phantom light parade
Hey there mates...I figured I would turn to my brother for this mystery. I have a 1994 Jaguar XJ12 87k miles..the check engine light was because of a failed distributor cap. We gave the car a full tune-up with all fresh parts. Local garage indicated in order for me to turn the check engine light on I must then disconnect the battery..which we did. NOOOOOOOOW the bloody transmission limp mode light is on...I have attempted to reset by disconnecting battery to no avail. I guess I am first wondering why that is on now.what would have caused the car to go into limp mode..and what steps shall I take to make it go off. Thank you in advance..I am forever grateful!
The setup on the XJ12 is a little different, but the most common cause of Limp Home Mode on our '93 XJ6 has been oil contamination of the electrical connector for the Throttle Position Sensor (TPS). Both the ECM and TCM use the signal from the TPS for determining gearshift points, shift timing retard, etc. You might check to ensure that during your tuneup the connector wasn't disconnected or jarred loose. It's also well worth disconnecting the connector and flushing both halves with zero-residue electrical contact cleaner and allowing it to dry before reconnecting it.
If cleaning the connector doesn't work, another common cause of LHM is contamination of the TPS itself. Yours may be a little different from ours, but the photos below show how I and many others have drilled drain holes in the TPS case to enable flushing it out with contact cleaner.
Finally, the most recent cause of LHM on our '93 was a failed cold solder joint on one of the circuit boards in the TCM, but before we go there why don't you check the TPS connector and we'll go from there.
Cheers,
Don
Welcome to Jag-lovers - Members Photo Viewing Page
The following 2 users liked this post by Don B:
93SB (05-23-2014),
Crownewourth (04-28-2014)
One question that comes to mind is, what was the fault code that caused the CEL to illuminate (that you traced to the distributor cap)? I'm wondering if a related fault could be causing the LHM....?
Cheers,
Don
93SB (05-23-2014),
Crownewourth (04-26-2014)
Do you know what transmission you have? The late 6-cylinder cars use a ZF 4HP24 electronically-controlled gearbox, but I seem to recall that the 12-cylinder cars used a Getrag or GM gearbox. If you know the model, there may be a troubleshooting guide available as there is for the ZF gearbox (there's an excellent one in the XJ40 eBook at the Jag-Lovers forum).
Cheers,
Don
93SB (05-23-2014),
And I wouldn't forget about oil contamination of the TPS electrical connector or the TPS itself - it's possible the battery disconnection was not actually the cause of the LHM.
Don
93SB (05-23-2014)
BrentGardner
28
04-26-2024 04:08 AM
