XJ40 ( XJ81 ) 1986 - 1994
6.0 V12 Accelerator Cable Adjustment
Old 11-12-2014 | 08:23 PM
Rok_Dr's Avatar
Default 6.0 V12 Accelerator Cable Adjustment
Hi All
Lady Penelope has always had a bit of hesitation between putting my foot on the accelerator and starting to move. Over the weekend I had a poke under the bonnet and found that there was a bit of slack in the accelerator cable with a 2.5mm gap between the accelerator cam and the throttle linkage plate.
I tightened the gap up to 0.5mm using the barrel cable adjuster, which has significantly improved her response. The attached pic illustrates.
Is 0.5mm too tight/loose and if so what would people recommend as an appropriate gap?
Steve
Attached Thumbnails 6.0 V12 Accelerator Cable Adjustment-dsc00521-2-large-.jpg
Old 11-13-2014 | 01:39 PM
Don B's Avatar
Hi Steve,
I adjusted the throttle cable on our '93 while the engine was running so I could eliminate as much slack as possible without raising the idle rpm. I listened for an increase in rpm and checked the tachometer to confirm. Here's a link to photos of the job on our N/A 6-cylinder:
Welcome to Jag-lovers - Members Photo Viewing Page
I agree that removing the slack produces a significant improvement in engine response to pedal input.
Cheers,
Don
Rok_Dr (11-13-2014)
Old 11-13-2014 | 11:31 PM
Rok_Dr's Avatar
Many thanks Don
That's a good writeup.
Steve
Don B (11-14-2014)
1100me
07-24-2023 07:10 PM
Gus
10-15-2019 01:29 PM
Richard_gib
09-12-2015 08:08 PM
AtholC
09-09-2015 10:07 PM
1100me
09-07-2015 07:26 AM
Quick Reply: 6.0 V12 Accelerator Cable Adjustment
