6.0L V12 Bell Housing Needed
Received 1,236 Likes
Jaguar never made a manual shift 6.0L V12, from the factory.
but google these companies,and there will be somthing that will work.
what transmission do you plan to use?
try;
McLeod racing prod.
Trans-Dapt
advance adaptors
i used the simple Trans-dapt, fro Buick/olds/pontiac, for my 78 5.3.
most important is the alignment dowel holes for GM trans, the 6l block is the same as a 1955 chevy(figure that one), you may have to drill &chamfer countersink holes, just examine things and be sure you order the right housing.
nowaday there are more combinations to pick from, but better ways also!
hope it helps!
try;
McLeod racing prod.
Trans-Dapt
advance adaptors
hope it helps!
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
60, 60l, adapter, bell, bellhousing, bellhousings, dowels, housing, jaguar, manual, tko, transmission, v12
