'88 xj40(xj6) abs brake pressure switches
ok...so I've soldered up the cracked connections in the ABS relay, I've installed a new accumulator sphere and replaced both the charging and low pressure switches... However I still have "low fluid level" and "low brake pressure" warnings on my VCM.
I know it's probably in the forum somewhere, but I have limited internut time to search thoroughly, so can anyone please tell me the correct wiring colours for the pressure switches just in case I have wired them in the wrong position? or any other heads up would be appreciated.
