90 XJ6 Reving issue
Here is the issue that I am having - once warm the car only reves to about 1.5 rpm and starts to bogg down
video below
90 XJ6 rev issue - YouTube
Any help or suggestions would be appreciated
Just a note when cold it revs up all the way with no issues
video below
Have you got a Haynes Manual? For starters Refer to chapter 6 - Exhaust Gas Recirculation (EGR) System and also the Crankcase ventilation system... I'm thinking that your fault lays here.... if not then
Have you got the standard hydraulic brake set up? or has it been converted to a vacuum booster?
Have you checked for cracks in your manifold?
Have you checked your O2 sensor?
Have you checked the TPS?
Have you replaced spark plugs/wires/rotor/dizzy cap?
Have you tried disconnecting the air filter and running it?
Have you run a compression check?
You might also like to look at the TSB regarding NOT revving your engine above 2000 rpm in Park or Neutral... it can damage your transmission
It could be anything but these are good places to start...
While I've got my thinking cap on, it might also be worth checking and cleaning your Mass airflow sensor (MAF)... it's the big metal thing between the air filter box and the intake manifold... these gunk up with oil as does the crankcase ventilation hose.
Remove your MAF (but don't disconnect the wiring) and see if there is any improvement, if not, disconnect the wiring and try...
So i had some time to take a look at the car today.
First of all my cap and rotor were replaced a couple weeks back and ignition coil was replaced when I purchased the car 5 months ago only things I have not replaced are wires and plugs but those both look fine
I have checked all the intake and breather hoses and they are all sealing properly no cracks etc..
Also checked to see if there are any cracks in my manifold - no issues there
Took apart the entire intake system from filter to the throttle body not dirty at all but still cleaned it all with throttle body cleaner
Issues is still there
Compression check also done and all is fine there
Checked for codes - no codes
Also disconnected the MAF with all the wiring still attached and ran the car - started for a second or two but then dies every time should that be happening?
dwiniarz,
It doesn't sound right that your engine dies with your MAF disconnected from the inlet manifold with the wiring still connected. try leaving it in place, just disconnect the wiring, remove your air filter and report back with the result?
Have you got a Haynes manual? The procedure for testing it is in chapter 6
According to Haynes, for a MY 90, Idle Potentiometer is not operating in range. I have never worked with it, so can't help with trouble shooting. The codes for the TPS are 17, 18 & 19, so this may be a different component, not sure which one though.
Hi - you should get the engine management .pdf, it's a must have for issues like this.
You can download it from the stickies at the top of the XJ40 forum page. It'll tell you how to approach your fail code and give you possible causes.
As Rob says, a quick look says fuel fail 11 on 90-92 MY engines is an idle trim issue.
rusty37
04-05-2020 07:40 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
