'91 XJ6 Rotors
Guest
Posts: n/a
RE: '91 XJ6 Rotors
There are all-different kinds of companies making drilled and slotted rotors. Unless you are in to heavy fast stop and go driving like autocross, you don’t need em. Having metal braided brake lines will be a better upgrade for the money. $170 for a set of four sounds too cheap. Usually, Brembo goes a pair for that much. Cheap aftermarket rotors tend to crack under hard driving. So if you going to invest in it, get a brand name. Also, contact the manufacturer for a brake pads recommendation. Not all rotors and brake pads work great together.
I am a Nissan nut not a Jag head but these are general recommendations for any car.
