93 rear lower control arm bushings?
I'm having trouble cross referencing the inner shaft bushings for the rear lower control arm. CAC4713 is most commonly referred to as 95-97 but does it go back to 88 or some other year?
Or any aftermarket bushing part # specific to 93 to 88 stamped steel control arms?
Jerry, thanks for looking. I have indeed already bought and installed those numbers from RA, (prices were untouchable!) but those are front suspension lowers.
https://parts.jaguarlandroverclassic.../brand/jaguar/
It shows CAC77601 in the upper location. Good. Found those everywhere.
It shows CAC4713 in the lower location (the location I’m interested in) but only FROM VIN 696460 Which is the start of the newer cast arm for the 94 40’s and the 300’s per bulletin H11. (I am VIN 671XXX)
Obviously the OD would be the same for both numbers, same pendulum.
Probably same ID if same pendulum bolt.
Variable is probably length or something else about the inner sleeve for mating to the cast arm.
So, which number to use for the stamped arm?
abercanadian
from Jag-Lovers pointed me to:https://parts.jaguarlandroverclassic.../brand/jaguar/
Wow, sorry I couldnt bother to read what you typed. At the Jaguar Land Rover site it says that that rear lower bushing is the same from 594576 which, I think would include the later stamped metal arms and through the cast arms too and lists that number. So that would mean that the CAC4713 number should be right. Barratts lists it, and the times I have called them for clarification they have been very helpful. Good luck.
Bussing
hilaryv215
09-24-2014 10:56 AM
mikewv100
02-19-2013 08:17 AM
daboss085
11-11-2012 03:45 PM
