94 XJ6 wiper problem
mrtalkradio yep it wont complete the cycle. the wipers intermittely work in the other speeds. If you take the wiper off the windshield it works. if you use the intermittent cycle it screws the wiper sequence up completely. any suggestions would help. thanks
I had the same problem on my 90,what happened was in the winter the wipers were turned on with a lot of wet snow on the windshield and stopped half way. After cleaning the windshield of snow an starting the wipers they would not complete a full cycle when in the intermitent mode,but worked fine a full speed. Replaced with a used wiper motor which i bougt from a salvage yard and it worked as it ahould.
petek57 (08-27-2011)
In regards to the problem that I had asked about, the issue is a fuse under the passenger side kickplate. You will see it just hanging there. 99.9% sure if you change that fuse the intermittent wiper action will complete its full sweep. Do a search in the forum, as i had to do on both my 90's. There is even a picture on here somewhere of the exact location and what it looks like. It fixed both my cars problem with that intermittent setting. Hope that helps.
petek57 (09-03-2011)
I know you fixed your issue, but here is where that fuse is. And for anyone whose wiper's don't park while being in intermittent mode.
Yari (02-23-2013)
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
I know this question was asked a while ago and the problem may be fixed but others may be experiencing the same thing.
It may be the fuse as mentioned if it is happening in int mode, it is a 10 a if I recall and is located in the right foot well behind the knee bolster sort of inline not in a block it is a blade type fuse (ATO). Change that if the problem happens during intermittent mode.
If as stated there was heavy snow or the arm was frozen in place it may have slipped on the splines and just need to be removed and properly placed, just remove the hold down nut, pull off the arm and replace in the proper park position.
Or... maybe the park switch is cracked, it is located under the top cover of the wiper trans box, remove the cover and run the wipers and see where the cam is contacting the switch when the wipers are turned off. You may need to remove it and and position it where it contacts the switch later. It may be cracked or loose on the shaft, you can try gluing it that may work.
Please use extreme care when working around the wiper mechanism, it has alot of torque and can really hurt you.
Hope this helps.
Hope this helps.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
The following 4 users liked this post by sleepycat:
This picture doesn't help? That is the location of your wiper motor fuse. The microswitch that is spoken about in an above post is under the cover of the wiper motor, under the hood.
pipedreamer (10-07-2013)
