Added refrigerant and compressor kicked on for only 10 min
I had not had the a/c on this car work in 3 years. I checked the shraeder valves and no gas vented out. Upon adding a can of refrigerant, the compressor kicked on. The vents were blowing cool not cold air. Then the compressor kicked off and has stayed off since. The low side pressure reads now 30psi with an additional can of refrigerant hooked up to the manifold gauge set. I guess the compressor needs to kick on to draw in the 2nd can? But I can not seem to recreate the condition that allowed the compressor to kick on. I would check the compressor relay if I knew where it was. So, where is this relay. Any advice is appreciated.
supra-raleigh (10-16-2014)
The following 2 users liked this post by Lawrence:
manwich66 (10-15-2014),
Jaguar Forums Editor
Jaguar Press release
09-28-2015 05:18 PM
