After two years of ownership..the oil leak is getting fixed!
With the weather changing, I figured this would be a good time to get this leak fixed, since I run 10w-30 in the winter and from experience, it leaks a lot faster than 20w-50, which is what I've been using as a summer oil. The oil cooler lines leak (I believe the first time I had the oil changed, that the mechanic I had do it smacked one of the lines while getting the filter off) and oil isn't getting any cheaper. So, I have the bypass elbow, the connectors and the 4 o-rings. Is there anything else I'll need to do this or this all I need?
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (10-04-2016),
dhatfield12 (09-29-2016)
While the due date for an oil change is around the corner, I'm thinking of disconnecting the lines while the filter is off (I take out the air intake plumbing for better access to the filter) and then, get underneath somehow and cut the lines as far up as I can get so that they're out of the way, and won't flop around and possibly break something else. Even if this isn't the only source of my oil drip, installing a bypass will definitely slow it down..and eliminate the hot oil smell I get whenever the warm oil starts to pass through the lines
Since the oil filter housing mounts with just four screws and is a common source of oil leaks, in my humble opinion it would be short-sighted not to remove it while you have easy access, clean the mating surfaces and seal it with a good bead of Ultra Grey. It will also be easier to install the connectors and bypass elbow with the housing removed.
I'd also recommend that you address the oil filler tube housing, and the dipstick tube seal (which you can probably just replace with a piece of rubber tubing from an auto parts store).
Having a leak-free XJ40 is a wonderful thing - now's your chance!
Cheers,
Don
Cheers,
Don
93SB (10-04-2016),
Very true. I have limited tools, but that hasn't stopped me before! It's dark now here in Illinois, but tomorrow morning, I will see what I find. Is very reassuring knowing that there's people out there that have plenty of knowledge on these cars, everyone here in my town is afraid of it (and claims they can't find parts...), so I usually end up doing my own work, unless it requires the entire vehicle coming off the ground!
Upon closer inspection, I found that the cylinders for the bypass fit in the housing very loosely, and the oil cooler lines were nice and tight. A note: when I was loosening the nut for the lines, the feed line wasn't in all the way, therefore causing a leak. Can anyone say sabotage? When I first got the car, the lines didn't leak. But the leak started after I had a shop change my oil..luckily I hadn't been back since but that's still crazy. I damaged the nut trying to re tighten the bypass earlier, so I'm getting a new one, but I'm just gonna put the lines back in and see what happens.
Ok, in my experience the o-rings are a pretty tight fit and as far as I can tell there should be no way they could leak.
Here's my unit and the replacement procedure - I had the wrong size rings at first but even those didn't really leak - however, the "wrong" ones were only a temporary fix after breaking a couple so as soon as the right ones arrived, they got replaced.
Are you using used or new o-rings?? old ones could be compressed and unable to seal.
here's my replacement thread with a few pics...
https://www.jaguarforums.com/forum/x...2/#post1332052
Larry
Larry
93SB (10-04-2016)
...not only thicker, much "fatter" too! - when fitted they have a larger diameter than the cylinders.
Someone supplied you with the wrong parts, as Don said they are way too skinny! Correct ones fill the recess completely ...no wonder you've got a leak!!
You can buy the correct o-rings online for as little as $1.25 each, I think I got mine from car parts discount (no affil)
Larry
Larry
When I found the ones I got, they were about under $1 each or so, I don't recall the exact price. Will be getting the correct o-rings and a new nut (cause I damaged the original) and try again as soon as I can. I am also going to look in as far as I can to see if possibly the gasket on the oil cooler adapter or the gasket between the adapter and filter plate are damaged. Luckily I had this problem in town instead of on the interstate!
