XJ40 ( XJ81 ) 1986 - 1994
Air Conditioning Fan
Old 07-04-2008 | 07:11 PM
Big E's Avatar
Default Air Conditioning Fan
I have an '88 Vanden Plas and believe that my air conditioning problem stems froman inoperativefan. This is the fan that is to the left directly behind the grill. Should the fan run constant?
Old 07-05-2008 | 12:08 AM
Thermo's Avatar
Default RE: Air Conditioning Fan
No, the fan should not run constantly. When you set the fan to off, it should turn off. If it is remaining on, then you most likely have a bad relay or a bad dash switch. It should turn off when the setting switch is set to OFF.
Chris "thermo" Coleman
Old 07-05-2008 | 09:27 AM
badmojo's Avatar
Are you saying that the fan runs constantly or that it doesn't run at all? My 95 used to blow fan fuses sometimes when it got really hot outside and it ran alot. Replacing the fuse would usually take care of the problem.
mbergen
10-23-2019 11:26 PM
Guy-Pierre Boucher
09-16-2015 06:55 PM
Jaguar_libra
US Western
09-09-2015 05:20 PM
SCMike
09-09-2015 10:30 AM
1100me
09-07-2015 07:26 AM
Quick Reply: Air Conditioning Fan
