air filter
Received 10,978 Likes
to clarify are you talking about just a k and n replacement filter element which obviously just replaces the original filter element or are you talking about an air intake system? if you are talking about an air intake system it would probably have to be one of those semi universal types that is not much more than a tube with a cone filter on the end which draws air from inside the engine bay which isn't ideal because although you get more flow the air will be hot which in turn isn't good for horsepower
better if you can figure out some way to draw in cooler air from somehwere outside of the engine bay or some guys leave the filter in the engine bay but fabricate a shield or encloseure to segregate the filter from the heat
cheers
cheers
xjrjag
09-27-2015 01:53 AM
1964Daimler
09-09-2015 11:28 AM
