alternative fuel pump
Roger:
Sorry, I've been away for a while. What year is your car? Based on your question, I'm guessing '91 onwards... I've never heard about anyone adding an additional fuel pump to a car with a pump in the tank. And I'm guessing your question stems from not wanting to pull the tank for a proper pump renewal. Perhaps one of the techs will have a definitive answer. Meanwhile, I'm wondering if you've done a few of the basics: fuel pressure test, fuel filter change, fuel pressure regulator...
cheers!
Scott
cheers!
Scott
Roger,
In a word, NO.
The fuel has NO way of getting OUT of the tank without that pump pumping it out. There is NO provision for a "gravity feed" from the tank, and to fit one would require the tank being OUT of the car, so nothing gained.
The tank out is not that bad, it looks worse than it is, and YES, many things need removing to do so, but it is methodical.
I had the X300 one out in about 2 hours the first time, and MOST of that was getting the DUMB fuel lines out of the bottom of the tank. The second time (new pump was noisy), it took less than 1 hour all done.
In a word, NO.
this difference of 55 psi will increase your pump output by about 50%
if the in-tank pump is a turbine pump .
