alternator/generator replacement ?
I am replacing the alternator on my 93 xj6, The person who owned it before me fried the old one, I just want to double check the correct wiring before I install the new one, Not sure if the person before me had it hooked up correctly, There are 3 connection points, The Plug, The lg main terminal & one more small wire, The first 2 are obvious. On the alternator there are 3 small nuts that hold the shield on, one of these has a piece of metal held on by a nut & a phillips head screw, This IS NOT where they had the small wire connected, it was connected to the other small nut, Not sure if that was correct, I would think it would connect to the phillips head screw ???
Thanks in advance for any help.
Jim
Jim
![](http:///www.startermotor-alternator-store.co.uk/ekmps/shops/thestartermot/images/jaguar-xj-series-4.0-6.0-alternator-b379--[2]-5534-p.jpg)
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
Hi shoeboy,
Welcome to the Forum.
I looked for your introduction, but didn't find one. You really should file one.
I have an '88, so looking at mine isn't going to help you.
Perhaps we can figure it out. Here are Hayne's wiring diagrams of the XJ6 starting and charging systems.
![](https://www.jaguarforums.com/forum/attachments/xj40-25/9701d1303225550t-roadside-repairs-jaguarxj6haynesrepairmanual1988thru1994-jpg)
There are two types. I am assuming yours is on the right.
However, it shows 5 wires with 4 connections to the generator; not counting the ground.
You should have a
You should have a
- WHT/YEL coming from FUSE 1
- WHT/BLU to the INST PACK
- BLK coming from the STARTER
- BRN coming to/from the SUPPRESSION MODULE and
- BLK coming to/from the SUPPRESSION MODULE
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
Wes Steenrod
09-06-2015 06:52 PM
KarimPA
09-03-2015 07:32 PM
