Bad pump??
Bad pump??
I pulled the fuel filter and turned the key. No gas was pumped. I then switched the gears and still no gas. I thought I heard the pump priming but I guess not.
I have learned from the search on this forum that if you switch into drive with the key on the pump will kick on. Is this true? Will it kick on with just the turn of the key?
I also heard I can jump the fuel relay by jumping a wire but not sure how.
New to the site so Hello. Thank you
1964Daimler
09-09-2015 11:28 AM
