Belt Removal Help
I need some step by step help and advice on a belt removal. I have attached some pictures of a belt I found deteriorating and I want to replace it before snapping as its begun to tear on the outer edge.
Essential could you explain exactly what it is? where might I find one to purchase (Vancouver area)? and most importantly how do I remove it?
Last edited by GGG; 01-18-2014 at 03:24 AM. Reason: edit typo in thread title so it appears in searches
Jag-GM (01-17-2014)
Well I've never taken one off but looks fairly straightforward - in your pic #5, looks like you slacken off the air pump mounting bolts and move the pump towards the thermostat housing - with the belt now slack, you should be able to remove it. Install the new one then lever the air pump back into position and re-tighten the bolts - offhand, I don't know the correct belt tension but the spec is probably listed somewhere in Haynes?
cheers
cheers
here's a belt for around $7, it's in the states though ...(no affil)
1994 Jaguar Vanden Plas Accessory Drive/Serpentine Belt 10 X 580
The following 2 users liked this post by GGG:
Jag-GM (01-17-2014),
mrtalkradio (01-18-2014)
aholbro1
08-05-2021 05:02 AM
dragonfly777
Regional
09-08-2015 01:39 PM
