XJ40 ( XJ81 ) 1986 - 1994
Blown hose, any tips on replacing it?
Old 08-04-2018 | 08:38 AM
Kay's Avatar
Kay
Default Blown hose, any tips on replacing it?
Hello
My Kitten decided that it is time to change the water inn the cooling system completely and it blew a water hose. One minute I am picking up speed nicely (bit over 5000 rpm on the clock) getting to the motorway and the next there is a huge cloud of steam behind the Kitten... Old hoses and high rpm, nice combination.
Anyway, I have found the blown hose, it is part number EAC3454 shown as part number 3 in the pic
Now the question is that is there a good (or even a reasonable) way to get to it to change it, part has been ordered already (as is the water pump gasket). My own guess is that it might be possible to get to it by taking the water pump away and then I might be able to get to the other end too without taking off the intake manifold.
Any advice is appreciated!!
Kay
Old 08-04-2018 | 08:41 PM
XJ6Paul's Avatar
I've read about the job here but have not done it myself when I had an XJ6:
https://www.xj40.com/viewtopic.php?f=9&t=997100
Kay (08-10-2018)
Old 08-04-2018 | 09:18 PM
jerry_hoback's Avatar
I had a kit of all hoses, that one included. I changed it with not Too Much Pain by removing that AIR pump. I am not sure yours would have one. I did not remove the water pump. Its just a matter of folding the hose to make it slip over both tubes. By the way, if one hose is gone, you should probably consider doing more than just the one. Good luck!
The following 2 users liked this post by jerry_hoback:
Kay (08-10-2018), Lawrence (08-05-2018)
Old 08-12-2018 | 10:33 PM
Kay's Avatar
Kay
Hi,
Just a quick update on The Kitten, got the hose changed and it was a quite a job to get it done. Anyhow the new one is place and Kitten is purring nicely, all I am wondering is that should I bleed air out of the cooling system now and if I should what is the best way to do it?
I wonder why the old hose did not work anymore????
Old 08-14-2018 | 10:22 AM
Good deal that it's done. What did you do to get at it? "So far" I haven't had a problem with bleeding the coolant. I just keep an eye on it by checking before I go anywhere.
Kay (08-17-2018)
Old 08-14-2018 | 12:39 PM
Lawrence's Avatar
I think the system is self-bleeding, hope so anyway as I've never done anything special to bleed my coolant after a change of coolant or thermostat replacement.
Larry
Kay (08-17-2018)
Old 08-14-2018 | 08:23 PM
Jeh's Avatar
Jeh
Originally Posted by Kay
Hello
Kay
FWIW and Im a little late to the party. Mine developed a leak at number 13 and that required removal of the intake. Which to my point, is that its not that hard and my feeling at the time was since I didn't know the age of any of the hoses I just replaced them all. You might consider planning for that.
Kay (08-17-2018)
Old 08-16-2018 | 05:13 AM
Kay's Avatar
Kay
Hi,
I just took out some other hoses out of the way and got it done that way....
I am planning to get just about complete "hose job" done so changing the other ones too. But as of now I have enough of bruises in my hands for the moment!!!
Kay
Old 08-16-2018 | 04:09 PM
sanchez's Avatar
YEP. The system is self bleeding. I just completed the cylinder head removal on my car. After the job was done, I filled the system slowly via the coolant reservoir and there are no problems with air in the system.
Kay (08-17-2018)
Old 08-21-2018 | 02:54 PM
NTL1991's Avatar
Oh that water pipe hose...
I replaced mine when I did all the hoses a couple (or maybe a few) years back. It was seeping a little at the forward end. I removed the intake manifold nuts and bolts and all the intake plumbing and throttle body. I was able to get my hands in that way, but the hardest part of the job was slipping the new hose back on. I used a little dawn dish soap in a spray bottle to help lube it up. Some even use two sets of clamps on each end due to this being such a vital hose. Do not skimp on quality here.
Nick
Kay (08-25-2018)
wal74
11-13-2012 07:26 PM
Blue Lion
10-10-2012 05:55 PM
Newby
03-07-2012 09:55 AM
j_bond
03-11-2011 01:21 AM
2004x-type
08-26-2009 04:54 AM
Quick Reply: Blown hose, any tips on replacing it?
