"Brake" light comes on when applying brakes
92 xj40. "Brake" light comes on when applying brakes. Could the low pad sensor be causing this or is it possible that it is something more severe. If I recall correctly the brake sensor circuit remain "open" when the pads are low and would cause the light to remain on instead of only when applying pressure. All advice greatly appreciated.
Brian
Jagtechohio: You were dead on with my last post. Thanks again!
Brian
Cheers mate. If you depress the VCM button on the trip computer panel at the same time the brake light is being illuminated with your foot, you will see a warning come up on the dash where your odometer mileage normally appears. It will probably say "PAD", which means that either the front or rear warning sensor is worn out (there's only one on each end of the car). Sometimes the sensors are broken, mangled or just need the connectors cleaned.
Have a look at your pads and you'll probably see the fault.
If the warning says "FAIL", that will be another chapter in the book. Let me know what your dash reads.
Guest
Posts: n/a
Ha...my pad sensors must have been broken for years then. Even when I did brand new brakes and rotors all the way around at the end of last summer, pressing the VCM on the 93 xj6 would still yell PAD at me...not to mention I also had the red BRAKE light come on every time I hit the brake too. That also did that for years. Oh well, I didnt really think anything of it and now someone else has my baby... = (
