XJ40 ( XJ81 ) 1986 - 1994
Brake pressure warning light help
Old 08-03-2011, 05:02 PM
honkytonk's Avatar
Default Brake pressure warning light help
Hi,
Recently purchased a 1990 4.0l XJ40 sovereign in need of a bit of work. While driving it back from the chap I bought it from the brake pressure light came on, and then started flickering with no regularity on and off. Didn't seem to matter if we were moving or stationary.
Done a load of searching on the net trying to diagnose this - I've done the pumping the brake pedal and all seems fine. If I start the car up, the light doesn't come on for around a minute, sometimes 2 minutes, and then it will come on for maybe 30 seconds and then start flickering randomly almost as if a sensor was playing up. It then may disappear for a minute, and come back on. The brakes seem to work fine.
Due to take this round Europe soon so would like some guidence on whether I should be concerned about this, and if so, if anyone has ideas as to what I can check. The more detail the better Attached picture of the light below.
Cheers, Mark
Old 08-04-2011, 03:29 AM
Cadillac's Avatar
I got a same light on my Jag too . Coincidence ? Not , check your brake cables and sensors , in my case mine was cut off , I don't know which idiot for what reason cut if off , then after founding the smoking gun we replaced the wires , no problem since
JarodL
03-07-2024 01:39 AM
D.K
12-10-2023 02:05 AM
Jpav27
07-31-2022 06:43 AM
mbergen
10-23-2019 10:26 PM
dsnyder586
04-04-2019 02:38 PM
Quick Reply: Brake pressure warning light help
