XJ40 ( XJ81 ) 1986 - 1994
"Bulb Failure" Message Yet Again -FIXED
Old 05-19-2020 | 04:47 PM
gunnar_xj6's Avatar
Originally Posted by 88xj6
I think I have read all the posts on the subject. All bulbs are good. What I do see is that when the right-turn signal is on, the flashing directional indicator on the dash flashes much faster than it does for left-turn.
The actual exterior turn lights are flashing at the normal rate however. Thus I suspect the "Bulb-Failure" has something to do with the right turn indicator. What could it be? I am feeling like an idiot here.
Eight years later; I have that phenomena om my 1992 XJ40 Daimler. For a right turn the ticking begins at normal rate but after a couple of seconds the ticking speeds up, same style as on older cars
when a bulb is shot. But in this case if I go outside and take a look both front and rear lamps flash at the normal steady rate.
So, probably the circuit senses a difference in resistance of the bulb compared to the left side bulbs and tries to falsely tell me about a bulb failure.
I assume if I change to new bulbs things will return to normal.
Old 05-19-2020 | 06:47 PM
jerry_hoback's Avatar
Glad you got it fixed! What was the problem? I had a side marker out which bothered me for a little while, but I figured out that those were supposed to be lit.
jagent
06-05-2022 03:18 PM
rominempire
28
10-08-2020 11:39 AM
10 XF Premium
10-02-2015 10:22 PM
goingjag
09-30-2015 10:27 PM
Quick Reply: "Bulb Failure" Message Yet Again -FIXED
