Bulb out indicator question
I have a 94 XJ6 with a bulb out light yet all the lights are working. As a Volvo owner which also has this system I know the can be a PITA sometimes to fix but not all lights on in the circuit (ie lisc plate illumination USUALLY)
Anyone have any tips on this beside a clean and replace all sockets and bulbs?
Joe
Joe
I have found on my 1993 xj6 that the marker lights inthe bumper ends were working but the light out was on.The light out light would go out when driven in the rain. then traced it down to bad (loose or dirty ground for the side marker lights.Even after that the light would sometimes come back on,so when it did I would go out and hit the bumper ends with my fist and the light would go out.Im not sure yours is the same problem but it might be.
I had a similar situation on my 1990 XJ6 as Lumppy47. My Bulb Out indicator was lit and all the bulbs were working fine. I started going through the grounds and found one under the hood (bonnet?) that was corroded. Once I cleaned it and screwed it back down, the Bulb Out indicator went out. That was several months ago and about two weeks ago, the indicator light came back on. A quick check showed that the side marker light in the rear right bumper was out. I whacked the bumper end with my hand and the bulb lit up and the indicator went out. Gotta love it!
I know, I know. I originally looked at the schematic and didn't see the fog lights in the bulb integrity circuit. Now with the snow I haven't driven the car in about a month so it hasnt been to work to even look at. I am hoping for next week.
The car has only 2 other issue of concern one being the CEL for Fuel 37 and the other being the left fan motor not working.![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
I had made a half hearted attempt to track down the CEL and as started checking connections the blowers stopped working on all speeds except high and then again without explanation started working again.
Since the CEL doesn't have an effect on how the car runs I am waiting until spring to play with both as they may be related wiring wise. Im sure all will be fixed come spring along with a new blower motor.
I have the same problem just haven't taken the time to repair. I just read a post on another forum that in my case is the problem. The system only reads the lights on each side are pulling the same power. In my case one of the bulbs is incorrect for the light socket. I just need to pull and replace the incorrect bulb and the problem should be solved.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
It looks to be the back of the assembly that holds the bulb and aims it. I may get creative and try to "fix" it. I looked on the net and a new one is in the $250 range and used seems to be unavailable, at least for a 94.
