CD Changer - No Power
Ok so I'm probably bugging everyone, but I'm waiting on my manuals and the Santa Ana winds did a number on my antenna today, meaning no radio. I got some tapes but really the last one I made when I was 14 years ago...
I have no power to my CD changer. I fixed my fuse issue from my previous post, but no power is going to the machine at all.... It's all stock... I hit eject even with the car on and nothing happens, switching to CD on the stereo brings a code E-01.
Help!
... and yes that's one of the CDs I want to hear haha
Help!
This is just because I happen to have the users manual and not because I know all the fault codes, because I don't.
E-01 = Disc change malfunction. Solution = Consult your Jaguar Dealer.
I really like useful User Manuals, you'll see when yours arrives.
Don't know how good your eyesight is but there is another code E-07.
Magazine Ejection impossible. Guess what, Solution, Press the magazine eject button. If nothing happens Consult your Jaguar Dealer.
This manual makes great throne room reading.
"Dangerous", but I am assuming that your player is in the trunk/boot.
Whilst you are in the boot sniffing around with the panels off. Check the for an inline fuse from the CD player (I've got one in mine), the line should be "hot" with ignition on. Also check that the Earth/Ground lead has not come loose.
Slts,
Slts,
So I had the boot all apart Sunday but no sign of an inline fuse, I have another changer in my old Passat that may be compatible, I want to see if it's a wiring issue or the device itself. I'll see if that works maybe. I don't know what to do really but if I come across a cassette adapter it's winding up in my car until I figure something else out.
Thanks for all your help!
I had what sounds like the same problem E01 wont eject cartridge
all seems dead.one forum reckoned it was microswitches inside the changer i removed the unit from the car removed the cover and manualy
but carefully turned the white cogs inside the unit(one set put the cd
back into the cartridge the other set ejected the cartridge)so i at least
had my cds back lol removed the cartridge then replaced the changer in the car then disconected and reconected the battery (make sure you have your radio code) switch on and see what happens mine worked
and has been fine since i did have to move the cogs back to where they
started.i then put the cover back on.
Mine worked and figured i had nothing to lose by trying this
zzrpilot
zzrpilot
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
al_roethlisberger
09-09-2015 09:14 PM
