Check engine light!!!
Hi there, FF14 is a code for a coolant temperature sensor out of range (faulty) - Sometimes this can simply be a bad connection at the plug, try cleaning the contacts and clearing the code first.
To clear the code, disconnect the neg battery terminal for a minute. Make sure you have the radio code and leave the doors unlocked when you disconnect the battery.
If the code returns, replace the sensor -
Welsh Enterprises, Inc - Jaguar XJ6(88-94) / XJ40 Fuel/Emissions Switches, Sensors & Injectors Parts - Coolant Temperature Sensor - XJ6 XJS
Larry
Larry
Don B (12-28-2016)
Lawrence (12-29-2016)
Larry
Rogelio Serrano
10-01-2016 05:45 AM
