XJ40 ( XJ81 ) 1986 - 1994
Check Engine Light on and I have Questions
Old 02-05-2009 | 09:35 AM
ArmyJag's Avatar
Default Check Engine Light on and I have Questions
So this morning on the way to work she started a bit rough but quickly smoothed out to her normal quiet purrr.. About half way to work the exclamation point came on with a check engine message. Fluid levels are good and the Jag is purring smoothly with no apparent issues.
If I do the VCM check will this alert me to any codes that may have been set? Also do I have the procedure straight with Key on engine off wait 10 seconds then press and hold the VCM button to pull them?
Any thoughts, advice or corrections greatly appreciated.
Army
Old 02-05-2009 | 11:23 AM
ArmyJag's Avatar
update:
Did the above and got a check engine 3 on the display? Anyone have a list or know where one is so I can see what it is?
Also I decided to fire up the car and she started normally and settled in to a nice idle with no check engine light showing up?
Old 02-05-2009 | 11:29 AM
JagtechOhio's Avatar
Isn't 3 a coolant temp sensor code, and aren't they listed in your handbook under "Specifications"?
Old 02-05-2009 | 11:31 AM
ArmyJag's Avatar
No handbook came with her tried to buy one off of a member that had one up for grabs and never heard back....
While you were typing I was searching and of course you are correct JagtechOhio it's a coolant temp sensor code.
Calling my car parts place as we speak lol
Edit:
Outstanding I love my local foreign car parts place they have it in stock for 30 bucks
Old 02-05-2009 | 11:40 AM
I have a set of owner's literature for a 1989 XJ6. PM me if you are interested,
BrentGardner
28
04-26-2024 04:08 AM
fast40driver
04-19-2024 08:24 AM
philwarner
12-06-2021 08:13 AM
big d
09-03-2015 08:37 PM
daro31
08-27-2015 10:26 AM
Quick Reply: Check Engine Light on and I have Questions
