Chime Question
I have been hearing a "chime" sound for two days . It's exactly same sound as you would hear when you forget to remove the key from the car and leave your headlamps on .But in this case you know it continually chimes until you turn off your headlamp switch and it gets silence
In my car , I insert the key and wait the lights turn on and then start the engine . It chimes once and goes off and same happens as I shut down the engine ( chime once and off ).So, is this a normal operation or yet another glitch is immanent
![Icon Starwars](https://www.jaguarforums.com/forum/images/smilies/icon_starwars.gif)
Just been out to check, 92 XJ40. Lights on, open door = chimes. (close door or turn lights off).
Did you replace that faulty door switch, it could be that the car thinks there is an open door? Even when there is not.
So what happens when you start the car and then turn the lights on, and ..... then turn the lights off and stop the car (Nothing yes?)
Cheers,
Cheers,
