XJ40 ( XJ81 ) 1986 - 1994
Climate control
Old 05-03-2018 | 03:45 PM
Richard A. Stolfa's Avatar
Default Climate control
The heat won't turn off on my 1988 XJ40
Old 05-03-2018 | 04:37 PM
Don B's Avatar
Hi Richard,
I believe that in your '88 there is a separate heater water control valve mounted in the heater hose near the firewall in the engine compartment, part 1 in the diagram below. Its default position is open, allowing hot coolant to circulate through the heater core. It is shut off by vacuum, so if the vacuum hose is cracked or detached from the small elbow pipe visible on top of the valve, or the vacuum source is clogged, the valve will always be open and you'll have heat at all times:
Cheers,
Don
93SB (05-10-2018)
Old 05-08-2018 | 08:10 AM
Than you. I'll look for this. Does the valve ever go bad? I see they are available at a reasonable price.
Old 05-08-2018 | 09:42 AM
Don B's Avatar
Yes, the valves do fail, but check the vacuum hose and if you have a vacuum gauge test it for proper vacuum to the valve.
Cheers,
Don
93SB (05-10-2018)
metalmarty
11-14-2016 10:59 AM
Flakster
10-22-2016 12:04 PM
Don B
General Tech Help
11-09-2015 01:59 PM
JimC64
03-02-2015 09:07 PM
sjuraud
08-28-2010 03:11 PM
Quick Reply: Climate control
